Frutte Posted February 11, 2011 Report Share Posted February 11, 2011 Got the comfort flasher kit from the local volkswagen dealer, after reding the how to thread.But the colors of the wires included in the kit doesent seem to mach the wire color in the tread.The colors ive got: brown white green green/white black/whiteCan someone help me figure out what goes to where?Took some pictures of the wires and the relay. Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 11, 2011 Report Share Posted February 11, 2011 (edited) Read the how-to again as it explans the colour match sequence in a diagram. Edited February 11, 2011 by Mike_M Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 11, 2011 Report Share Posted February 11, 2011 Quote Link to comment Share on other sites More sharing options...
Frutte Posted February 11, 2011 Author Report Share Posted February 11, 2011 (edited) now that i look at the guide i se that the new looms wires are exact the same as the loom to the hazardswitchcould i just connect it color to color?Regards Fredrik (from sweden) Edited February 11, 2011 by Frutte Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 11, 2011 Report Share Posted February 11, 2011 If they are exactly the same then go ahead and match like for like.........its odd unless the UK version of the kit differs slightly. Quote Link to comment Share on other sites More sharing options...
Hipwell Posted February 11, 2011 Report Share Posted February 11, 2011 The coloured wires you have on the flasher kit will probably just match up to the same coloured wires on the loom for the hazard light switch.Brown to BrownWhite to White etc.But to be sure, check the terminal numbers for the new relayThis is what it should be with the correct wires...Brown (31) > Brown (31)Black/White (15) > Black/Grey (75a)Green/White (49a) > Black/Yellow (49a)Green (49R) > Black/GreenWhite (49L) > Black/White (L)So check on the new relay plug which terminal each colour wire goes to..Brown should go to 31Black/White to 75aGreen/White 49aGreenWhite to LIs the last bit correct for you wiring loom you have? Quote Link to comment Share on other sites More sharing options...
Frutte Posted February 11, 2011 Author Report Share Posted February 11, 2011 Fantastic.Thanks for helping me out lads!Exactly the info i was looking for. Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted February 11, 2011 Report Share Posted February 11, 2011 What exactly are comfort flashers?? I've seen all this info about them, but dont know what they are! Quote Link to comment Share on other sites More sharing options...
Hipwell Posted February 11, 2011 Report Share Posted February 11, 2011 What exactly are comfort flashers?? I've seen all this info about them, but dont know what they are! Allows you to touch your indicators once & they'll flash 3 times, as seen on later VW models. Quote Link to comment Share on other sites More sharing options...
Frutte Posted February 11, 2011 Author Report Share Posted February 11, 2011 its the "flick the blinker "stick" halfway once and the blinker flashes 3 times" mod Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 11, 2011 Report Share Posted February 11, 2011 Use mine all the time and had to install them after using the Mk5 Golf a lot , as missed them in the GTI LOL Quote Link to comment Share on other sites More sharing options...
