shaggy66bus Posted February 13, 2013 Report Share Posted February 13, 2013 well im back againthis time a 1.4sthe problem is when i start up it runs fine the starts to miss and judderwill it be coil pack or pebal box problemthe throttle pedel moves up and down by its self when it is doing thissome days runs fine then others judders and starts miss firinghelp its doing my head incheers karl Quote Link to comment Share on other sites More sharing options...
Rich Posted February 13, 2013 Report Share Posted February 13, 2013 You only ever come on when you have problems and that doesn't inspire me to help you out. Quote Link to comment Share on other sites More sharing options...
shaggy66bus Posted February 13, 2013 Author Report Share Posted February 13, 2013 erm rich i donti had a 1.4 sport and sold it never had any probs with thatbeen using my splittybut wanted another lupo so bought one . Quote Link to comment Share on other sites More sharing options...
tintin360 Posted February 13, 2013 Report Share Posted February 13, 2013 Check your spark plugs, might have oil in the spark plug wells Hope this helps 1 Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted February 13, 2013 Report Share Posted February 13, 2013 When the throttle pedal is twitching its the throttle body thats correcting. Its trying to stop the engine from cutting out, could be one of several problems, throttle body needs a clean and reset..first thing id try, cures most idle probs on lupos.Then id check breather system, vacuum pipes for leaks (your hunting issue) or if you have access to one, use a scantool or vagcom to see what codes you have, more than likely lambda or egr faults due to the throttle failing.Hope this is helpful. :-) 1 Quote Link to comment Share on other sites More sharing options...
