jcarroll Posted February 25, 2010 Report Share Posted February 25, 2010 Propbably been asked loads before...sorry if it has.Need to remove the partition between sides of my hard drive on my laptop. Both drives are named already so i think i need to just format itIts a mystery so help me!!! Quote Link to comment Share on other sites More sharing options...
99hjhm Posted February 25, 2010 Report Share Posted February 25, 2010 Windows? Vista? Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 Vista Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 25, 2010 Report Share Posted February 25, 2010 XP: http://www.rdweb.co.uk/removing_partition_hard_drive_using_windows_xp/ Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 XP: http://www.rdweb.co.uk/removing_partition_hard_drive_using_windows_xp/ThanksJust to check, this is what i need to do as i have filled one side, opening the other wont have any issues will it? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 25, 2010 Report Share Posted February 25, 2010 The partition you are removing needs to be empty and also not the c:\ drive which is normally the default install drive for software. Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 Well one side is empty and the other is full, the empty side is the D drive so i can use it for my docs and music and leave c for the programsSound about right? Quote Link to comment Share on other sites More sharing options...
Mike_M Posted February 25, 2010 Report Share Posted February 25, 2010 sounds ok. remove the D:\ and then that space will bolt to the c:\ Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 Ah ok, so by removing the name it turns it into just adds onto the c drive? Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 25, 2010 Report Share Posted February 25, 2010 You would be better moving your data to the D:\ and changing the default "My Documents" to that drive.This would mean that when you need to rebuild Windows on the C:\ you wont have to bother backing-up the data first. Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 But wouldnt that affect the file paths?Windows is on C at the moment, what do you mean about rebuilding windows? Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 25, 2010 Report Share Posted February 25, 2010 Sorry re-install Windows.If you move the Documents folder by right clicking "Documents"; "Properties" and using the "Location" tab to "Move..." your Documents to the D:\ it will change the registry entries to match.If you get issues, you can reset it in the same manner back to default.All of our machines at work have the My Documents\Documents folder pointing to the network and we have no issues.Check your D:\ is big enough first. Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 Ah ok, that makes more sense but im worried now that i have to install windows again.Can i not just move the bigger things,using that method, to the D drive? Quote Link to comment Share on other sites More sharing options...
Silver! Posted February 25, 2010 Report Share Posted February 25, 2010 It will move everything in your "Documents" folder and amend the registry paths so Windows and other applications can find them.I didin't say you had to re-install Windows now, but when you need to, or wish to in the future. Quote Link to comment Share on other sites More sharing options...
jcarroll Posted February 25, 2010 Author Report Share Posted February 25, 2010 Ah ok, i will move my docs and music and see how i get on.Thanks for all your help. Quote Link to comment Share on other sites More sharing options...
