Aftermarket Wheel & Airbag Light
I've recently fitted an OMP steering wheel to replace my standard one and the airbag light has obviously appeared! The wheel came with a 2ohms resistor which I fitted to the airbag leads, but for some reason this hasn't got rid of the light on the dash.
Am I doing something wrong or have I got the wrong resistor?
I know this topic has been covered a few times before, but having read most of them, they haven't given me a definitive answer.
Any help would be much appreciated! :)
  • 3 weeks later...
Did you disconnect the battery before replacing the steering wheel?
The light will stay on until the fault code has been cleared, even with the resistor fitted :thumbdown:
You may also fail your MOT as the airbag needs to be present and fitted on the vehicle at the time of the test, unless you have a friendly MOT man..... :thumbsup::thumbsup:
Cheers mate, just need to clear the fault then. Shouldn't be too hard! :thumbsup:
Looks like I'll have to swap back for MOT time, or give it my friendly tester :ph34r:
I also found this that should help, especially with my horn constantly going off to the point where I've had to remove the fuse! :doh:http://forums.clublupo.co.uk/index.php?/topic/60350-fitting-boss-kit-for-lupo/
Edited by T3LLIOTT
Yea my local Seat garage failed my MOT on Tuesday because of my Momo steering wheel :thumbdown: Going to try a different garage today, hopefully it'll pass this time :)
