G60 BRAKE SETUP
HI THERE LOOKING TO CONVERT MY GTI FRONT BRAKES FROM 256 TO 280MM G60 AS I CAN TELL FROM THIS GROUP THIS COULD BE THE NEXT MOD FOR ME. BUT THERS A LOTS OF TALK..... BUT NO PART NUMBERS FOR CARRIERS,DISK,PADS, OEM PART NUMBERS PLEASE, WHO'S THE DADDY ON THIS MATTER. :P
i'm using oe gti pads 6n0 698 151 b no problems as its only 2-3mm difference!
yep, sounds about right to me!
trade for the pair works out around £165ish
  • 1 month later...
ok so im having an argument on ebay with sum dude .. vw breakers .. hes saying that you cant get g60 carriers from vw any more ?? and the part number ive quated the part number above and he says thats the wrong thats 288 summit or rather from a golf so i dont know who or what to believe ...this is what the guy said !!
nope 357 615 125c is not the part number for 280mm g60 carriers at all... that is the part number for mk3 288mm carriers.. and yes etka is showing up with 100's of them in the country at various maindealers.. but there not GENUINE G60 carriers
any ideas ???
Edited by gilybob
erm..... the guy is a knob! The 288mm carriers as found on VR6 mk3 golfs is 4a0 615 125 a
there are 2 parts numbers for g60 carriers, the earlier part number is
857 615 125 (280mm)
which is upto 1991, then they are
357 615 125 c (280mm)
which can be found on
corrado 1989 - 1995
golf 1990 - 1996
golf synchro 1986 - 1991
golf estate 1994 - 1996
jetta 1988 - 1992
passat 1988 - 2000
vento 1992 - 1996
the 357 carriers are fine with Lupo's as I'm on my 3rd set of pads and second set of discs, and I've had NO problems whatsoever! My carriers came off a mk3 8v golf GTI with an ADY engine code (same as 2e and AGG) and I painted them red, as they don't come in red at all from VW.
Edited by lupogtiboy
thank you dude ill copy and paste to him .. apart from the knob bit..
i can get the 357 615 125 c (280mm for 47 pounds each from vw (mates rates) so ill order them nxt month thanks for the reply dude ..
MANY THANKS :P MOD COMPLETED AND PART NUMBERS ARE CORRECT G60 carriers - 357 615 125 c
G60 front discs - 535 615 301 .WAS VERY LUCKY WITH THE VW CARRIERS FROM THE SCRAP YARD,
DISC G60 STANDARD VW VENTED TYPE USED OLD PADS FROM THE VW GTI AS TO SAVE MONEY BUT WORK FINE.
ALL STANDARD VW PARTS ;)
