benjiii 2 Posted August 6, 2014 Report Share Posted August 6, 2014 hi, the mrs has bought a lupo and the clocks are 10 mph out, and when the engine is on tick over the needle is.. the only way I can describe it is saying -10, does this mean new clock? or is there anyway of fixing it? thanks Quote Link to post Share on other sites
danoid 58 Posted August 6, 2014 Report Share Posted August 6, 2014 best thing to do, is take the front plastics of the clock off, and move the needle to 0mph.I've only ever broken the clips trying to remove the front cover, but i'm sure someone will know the proper way Quote Link to post Share on other sites
benjiii 2 Posted August 7, 2014 Author Report Share Posted August 7, 2014 cheers mate, I don't suppose anyone knows how to remove them do they? Quote Link to post Share on other sites
danoid 58 Posted August 11, 2014 Report Share Posted August 11, 2014 Found ithttp://forums.clublupo.co.uk/index.php?/topic/76328-how-to-gti-clocks-in-a-non-gti/looks like you need to unbolt from the back, then the front comes off. I just pulled from the front and a bit broke so explains it 1 Quote Link to post Share on other sites
danoid 58 Posted August 11, 2014 Report Share Posted August 11, 2014 Also, when you move everything back to 0mph. I'd check with a sat nav that the new reading is true, you don't want to be doing 30mph on your clocks and your actually doing alot faster Quote Link to post Share on other sites
benjiii 2 Posted August 11, 2014 Author Report Share Posted August 11, 2014 Cheers mate ? Quote Link to post Share on other sites
