lisa91 Posted June 28, 2014 Report Share Posted June 28, 2014 can anyone explane how the vvt works exactly on the gti avy ? my plan is to put the cams/housing from a aub or afk 100bhp 1.4 16v on a avy gti meaning i will lose the vvt . really dont know if its going to work . still going tu be running from the 1.4 ecu im not trying to make more power(as long as its still at 100bhp) just an messaround with some parts i have ?? Quote Link to comment Share on other sites More sharing options...
Rich Posted June 28, 2014 Report Share Posted June 28, 2014 What exactly are you trying to do/gain from this ? Quote Link to comment Share on other sites More sharing options...
lisa91 Posted June 28, 2014 Author Report Share Posted June 28, 2014 im not trying to gain anything really the gti has a stronger bottom end ! i dont want to rip the dash out to change the loom for the sake of 2 extra plugs for the vvt also i have cable throttle and the gti is flyby wire so id haf to change peddle box . if it will run ok simply by swaping the cams id be happy . i know most of you will be thinking just do the full gti convresion!!!! Quote Link to comment Share on other sites More sharing options...
