WSMGti 0 Posted April 15, 2014 Report Share Posted April 15, 2014 After nearly a year of owning my Loop, I have only just clocked that most other Gti's have two catalytic converters on them and mine only has one, attached to the manifold, yet the sensor part way down the mid section is still in place and the pipe seems to be OEM ? Any ideas , I'm assuming that someone has removed it , will this cause an emissions test failure ? Quote Link to post Share on other sites
Pete 308 Posted April 15, 2014 Report Share Posted April 15, 2014 If the engine light isn't on it's working as it should and you won't have anything to worry about, mine only has one cat, didn't even know they should have two. Quote Link to post Share on other sites
WSMGti 0 Posted April 15, 2014 Author Report Share Posted April 15, 2014 (edited) It keeps coming on aha ! I just reset it , But as far as I'm aware they don't need two. Edited April 15, 2014 by WSMGti Quote Link to post Share on other sites
Pete 308 Posted April 15, 2014 Report Share Posted April 15, 2014 May have an issue with your sensor then, better to get it plugged in and see the root cause of it. Quote Link to post Share on other sites
WSMGti 0 Posted April 15, 2014 Author Report Share Posted April 15, 2014 I hope it's only that , I will do and I'll let you know what comes up Quote Link to post Share on other sites
