tintin360 Posted January 24, 2014 Report Share Posted January 24, 2014 I'm after some help, on the way home from work last night the car was juddering like mad when I tried to put my foot down, it happened at both high and low speeds and the engine sounds like it's about to cut out when I'm in traffic.When I got home, opened the bonnet to have a look, no oil in spark wells, no gunk around the oil filler cap, all I found was what looked like custard in the oil breather pipe that is attached to the air box, I cleaned it out the best I could and took it to the local garage this morning, I explained what has been happening, they have scanned the car and the following faults have appeared:01249 - injector cylinder 1 short to ground intermittent01250 - injector cylinder 2 short to ground intermittent01251 - injector cylinder 3 short to ground intermittent01251 - injector cylinder 4 short to ground intermittent The garage has told me it's either the fuel pump or the ecu. The juddering is driving me mad, had anyone ever had this problem and what did you do to fix it?Thanks for your helpSteve Quote Link to comment Share on other sites More sharing options...
tintin360 Posted January 24, 2014 Author Report Share Posted January 24, 2014 *01252 - injector cylinder 4 short circuit to ground intermittent Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 24, 2014 Report Share Posted January 24, 2014 A quick google seems to suggest the fuel pump relay is a good place to start Quote Link to comment Share on other sites More sharing options...
tintin360 Posted January 25, 2014 Author Report Share Posted January 25, 2014 Thanks Defcon5Do you know what relay number it would be? I'm thinking of checking the fuse, relay then wiring, am I heading in the right direction?Has anyone had the same problem and have been able to fix it? Quote Link to comment Share on other sites More sharing options...
tintin360 Posted January 25, 2014 Author Report Share Posted January 25, 2014 My oil breather pipe connected to my air box has what looks like custard colour gunk, is there anyway I can clean it without taking it off?Cheers Steve Quote Link to comment Share on other sites More sharing options...
Speed Bumps Are My Enemy... Posted January 29, 2014 Report Share Posted January 29, 2014 Hi there the relay is number 410 its behind the fuse box bit of a pain to get to best way of cleaning hose is to take it off as the box at back of engine will also be full of gunk if u take inlet off 3 allen bolts hold on the oil breather box Quote Link to comment Share on other sites More sharing options...
