Faraz Posted December 16, 2013 Report Share Posted December 16, 2013 Hi,The airbag light on my GTi recently illuminated so I removed the steering wheel at the weekend to get a look at the clock spring.I've taken a part number off it - 1H0-959-653-EHowever I'm struggling to find that specific part. I've managed to find 1H0-959-653 and 1H0-959-653-B.Does anyone know what the E/B stands for, or if I can use the other part numbers?Thanks Quote Link to comment Share on other sites More sharing options...
GeoffD Posted December 16, 2013 Report Share Posted December 16, 2013 that usually refers to revisions of the part or it makes the part more specific, ie a particular model on a particular year. it may be that your part has been revised. unfortunately the only people who can answer your questions are vw themselves or tps (trade parts supplies) who are a subsiduary of vw. geoff Quote Link to comment Share on other sites More sharing options...
Bigplum Posted December 16, 2013 Report Share Posted December 16, 2013 Are you sure it's faulty ? Maybe check it with a multi meter , as long as its disconnected from the airbag Quote Link to comment Share on other sites More sharing options...
Faraz Posted December 17, 2013 Author Report Share Posted December 17, 2013 Well its interesting you say that as I read the code when the fault first appeared, which led me to the igniter on the drivers side so I thought the clock spring was the likely culprit.When I took the wheel off the clock spring broke in half and I noticed the ribbon was twisted inside. I re-organised the ribbon, put it back together and fitted it, expecting that I would come back to it once I'd sourced a replacement.Since then, the fault code hasn't returned so maybe it was just a loose connection somewhere? Quote Link to comment Share on other sites More sharing options...
