cultiv8ed chris Posted October 14, 2013 Report Share Posted October 14, 2013 (edited) Hi all I'm after some help, I bought a 1.4 tdi arosa at the beginning of September from a member on here actually. Has been running great till last week when red oil light came on flashing and lost all power, but turned it off and on again and was fine till today when it did the same but wouldn't start for a few mins. I changed the oil and filter and also the oil pressure sensor at the weekend but this has obvs not fixed the problem. Just wondering has anyone else had this sort of issue before or ideas on what i can do. My next plan of action is take the sump off maybe see if there is some thick sludge in there getting stuck or if the seal from the pick up to pump is knackered. Any help would be great. Edited October 14, 2013 by cultiv8ed chris Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 14, 2013 Report Share Posted October 14, 2013 Does it sound ok?What's the mileage and service history like? Quote Link to comment Share on other sites More sharing options...
cultiv8ed chris Posted October 14, 2013 Author Report Share Posted October 14, 2013 Sounds absolutely fine get awesome mpg. The new engine is suppose to be 50k but don't no about the service history. Quote Link to comment Share on other sites More sharing options...
GeoffD Posted October 14, 2013 Report Share Posted October 14, 2013 ours did this after a service. I put on an oil pressure gauge to keep an eye on things and changed the oil pressure sender, the one on top of the filter housing. turned out to be the plug for said sender, which being a rattly diesel had worked loose, oh well, everything was ok, good news Quote Link to comment Share on other sites More sharing options...
cultiv8ed chris Posted October 15, 2013 Author Report Share Posted October 15, 2013 (edited) ours did this after a service. I put on an oil pressure gauge to keep an eye on things and changed the oil pressure sender, the one on top of the filter housing. turned out to be the plug for said sender, which being a rattly diesel had worked loose, oh well, everything was ok, good newsDrove to work today in it not a problem but will see it goes over the next few days. Just hoping if it does conk out it starts back up as don't want to be stuck. I'm thinking it might be wiring/plug as they have definitely been played with before. Edited October 15, 2013 by cultiv8ed chris Quote Link to comment Share on other sites More sharing options...
GeoffD Posted October 16, 2013 Report Share Posted October 16, 2013 the single wire going to the sender is the one to look at, it looks on but invariably the connection is intermittent which gives you your flashing light. ours didn't cut out mind, perhaps I got to it before that started. ours is the humble sdi though your tdi may have more bells and whistles than ours, good luck , geoff Quote Link to comment Share on other sites More sharing options...
