loepan 34 Posted September 14, 2013 Report Share Posted September 14, 2013 hi,im having a brain fart of sorts....and cant believe i'm askinggot some mud flaps (oem)I was assuming fitting them would be a case of removing the arch liner, slotting in-between plastic bumper and arch liner, screwing back up?the top part of the mud flap has a sort of lip, I cant seem to locate that correctly? it doesn't seem to have any where to go Quote Link to post Share on other sites
GTIChris 114 Posted September 14, 2013 Report Share Posted September 14, 2013 Not taking the wee wee but you do have the front on the front and the back on the back don't you ? Quote Link to post Share on other sites
loepan 34 Posted September 15, 2013 Author Report Share Posted September 15, 2013 Only have one set, thought this myself:-) Quote Link to post Share on other sites
gatesy0093 11 Posted September 15, 2013 Report Share Posted September 15, 2013 I think it goes like thisThe front mud flaps should have a little slot at the bottom of them to fit over the sill. They do however need different arch liners (I think) because the original ones come up infront of the sill which means the mudflap won't sit properly. You could just cut the old arch liner to make it fit. The mudflaps sit on top of the arch liner and only have like 2-3 screws holding them on. The little tab at the top should have a metal clip. Un clip it, then place the tab on top of the liner and push into the arch itself (if they aren't rolled) then the metal clip should slot onto the plastic tab making it so it cannot undo. If you have rear ones. They are pretty straight forward as they only need to tuck under the bumper and screwed in placeHope it helps pal Quote Link to post Share on other sites
