jakefresh Posted June 6, 2013 Report Share Posted June 6, 2013 Hello! I've changed my door on the drivers side and the central locking stopped working so I swapped the door loom over and the same problem so I presumed it was the lock/latch mechanism so I replaced that. Still nothing. The problem is that both doors do lock but they don't use the central locking its a Manual lock. Where you can gear the motor turn bit its not powered. Helpppp!!!!! 3 Quote Link to comment Share on other sites More sharing options...
