craigburn123 Posted March 20, 2013 Report Share Posted March 20, 2013 Ok so I've just fittited new door speakers and 6x9's next thing is to get a sub and amp but how to I wire them as alll the wires into headunit are in use? Also what do crossovers do Quote Link to comment Share on other sites More sharing options...
Pete91 Posted March 20, 2013 Report Share Posted March 20, 2013 What head unit do you have? What you need are pre-outs Quote Link to comment Share on other sites More sharing options...
Vinnyzf Posted March 20, 2013 Report Share Posted March 20, 2013 You need at least 1 pre out. This looks like a normal rca input. (white and red)You then wire up an amp. Monoblock if you're simply doing a sub. Or 4 channel if you want to do the 6x9s and the sub. Its hard to explain over the internet. You'd be better researching it yourself, few youtube vids. or going into a car audio shop and asking advice.Usually you need a video or someone to actually show you, it's hard to do it all just from reading something on a forum. Quote Link to comment Share on other sites More sharing options...
manilasuperstar Posted March 20, 2013 Report Share Posted March 20, 2013 (edited) I hope dis would help, http://www.crutchfield.com/S-7vIpoteHvBv/learn/learningcenter/car/amplifiers_wiring.html Edited March 20, 2013 by manilasuperstar Quote Link to comment Share on other sites More sharing options...
Vinnyzf Posted March 20, 2013 Report Share Posted March 20, 2013 I hope dis would help,http://www.crutchfield.com/S-7vIpoteHvBv/learn/learningcenter/car/amplifiers_wiring.htmlLooks complicated! If you gave it a good read it would probably help Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 21, 2013 Report Share Posted March 21, 2013 Crossovers usually send certain frequencies to certain speakers well when wired correctly. E.g. You have a tweet and a mid woofer. If you send 100hz to the tweeter it will damage it and sound naff. So the crossover splits the frequencies high to high and low to low. This is a super super simple way of describing it. Then you get into crossover slopes with octaves and passive or active crossovers 2/3/4 way etc. Quote Link to comment Share on other sites More sharing options...
vince172 Posted March 21, 2013 Report Share Posted March 21, 2013 What head unit do you have? What you need are pre-outsbefore going any further, need to answer this question! Quote Link to comment Share on other sites More sharing options...
