VolkswagenDan Posted March 14, 2013 Report Share Posted March 14, 2013 Hello,My passanger window doesn't go all the way down.... it stops like you would expect rear electric windows to on other cars (with a few inches spare)Is this the case with all lupo's or is my regulator fecked?Cheers,Dan Quote Link to comment Share on other sites More sharing options...
sharpelupo Posted March 17, 2013 Report Share Posted March 17, 2013 Hello,My passanger window doesn't go all the way down.... it stops like you would expect rear electric windows to on other cars (with a few inches spare)Is this the case with all lupo's or is my regulator fecked?Cheers,DanTake the door cards off (upper and lower) and operate the window switch, see if there is anything clearly obvious thats blocking the windows operation and take it from there. (Make sure to use a torch to check the runners) Quote Link to comment Share on other sites More sharing options...
Pete91 Posted March 17, 2013 Report Share Posted March 17, 2013 The white clips that regulate the movement might need adjusted. To do this just unscrew the bolt in them and move them around by hand. Quote Link to comment Share on other sites More sharing options...
VolkswagenDan Posted March 17, 2013 Author Report Share Posted March 17, 2013 Thanks for the responses guys. Will have a look hopefully today when I get the chance. Did think it wasn't right..! Quote Link to comment Share on other sites More sharing options...
