Rickpercy87 Posted March 14, 2013 Report Share Posted March 14, 2013 Are you able to permanently remove the EGR valve on the 1.0's? I have read you may need to mess around with the ECU or change some wiring around as the lack of the EGR will report a fault to the lupo thus making it a non-runner. How difficult is it to achieve this and would it fail an MOT?Cheers guysh Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 14, 2013 Report Share Posted March 14, 2013 An EGR (engine gas recirculation) valve is simply there to reduce the emission a slight bit by re-feeding the exhaust gasses into the engine; it won't affect your emissions so much that it fails an MOT, being a 1.0. As for the wiring, it will more than likely show a fault code via displaying the EML on your dash, the engine will still run and a bit smoother if anything due to using a constant streem of clean fuel rather than a mix of used / unused vapour. Elegidly you can see throttle response improvement; but using a blanking plate for the egr port can raise the temperature of the head which in turn if your headgasket isnt up to the job will result in part failure.Hope this helps Quote Link to comment Share on other sites More sharing options...
Rickpercy87 Posted March 14, 2013 Author Report Share Posted March 14, 2013 (edited) Thanks mate that's brilliant! Pretty much hit the nail on the head!You reckon a plate with a heat shrink will do anything? Edited March 14, 2013 by Rickpercy87 Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 14, 2013 Report Share Posted March 14, 2013 Will need to withstand some corrosion so maybes source a aftermarket part, this looks like it would do the job, specified for diesels but it looks the rite shape http://item.mobileweb.ebay.co.uk/viewitem?itemId=140931794703&cmd=VIDESC Quote Link to comment Share on other sites More sharing options...
