joshthewacko Posted January 21, 2013 Report Share Posted January 21, 2013 I just got my lupo s last saturday and although the guy told me that the windows don't really work and I'm not exactly mechanically minded, I was wondering if anyone on here has seen/know the solution to my problem.Basically, the driver's window will not go down if you press the switch, but if you put the key in the door lock and hold it turning right the window goes down and will go up if you pull up on the switch. My passenger window won't go up or down on either switch and the window comes down slightly when doing 70. I can take the doorcard off and get some pictures if anyone will find that helpful?cheers guys Quote Link to comment Share on other sites More sharing options...
nellytheelephant Posted January 21, 2013 Report Share Posted January 21, 2013 (edited) have a look at the relays see if there working then take the door card off and test the switch with a multimeter check all the wirings ok then have a look at motor as there a common fault on lupos due to the big windows Edited January 21, 2013 by nellytheelephant Quote Link to comment Share on other sites More sharing options...
