leighton88 Posted December 19, 2012 Report Share Posted December 19, 2012 Alright all...just a quick question as to how to remove the brake reservoir and clean it as I'm currently changing the brake fluid in my gti and the reservoir is black with poop...here's a photo of the dirt Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted December 22, 2012 Report Share Posted December 22, 2012 Why on earth would you do that??? Just suck the old fluid out of the res, replace with new fluid, the bleed your brakes, simple! The res is sealed to the master cylinder so dont try to remove it! Quote Link to comment Share on other sites More sharing options...
leighton88 Posted December 24, 2012 Author Report Share Posted December 24, 2012 It's soo dirty...looks terrible!!..in the picture,it's empty as I already flushed the brakes fluid...is there a way of cleaning the crud in there? Quote Link to comment Share on other sites More sharing options...
Paul T Posted January 4, 2013 Report Share Posted January 4, 2013 I'm guessing here mate but if you try and clean it using cleaning products could affect nature of the brake fluid. Toothbrush? not your own of course. Quote Link to comment Share on other sites More sharing options...
DENTOUT Posted January 5, 2013 Report Share Posted January 5, 2013 Honestly, dont use anything to clean it, its just the reservoir! Its the fluid in the lines that are important! Just flush with clean fluid and away you go Quote Link to comment Share on other sites More sharing options...
leighton88 Posted January 6, 2013 Author Report Share Posted January 6, 2013 Thanks fit the response guys...the only reason I wanted to clean it is because the dark Line you see on the resiviour is dirt....I can't see properly how much fluid is in there....I think I will leave it as I know that it can be abit costly if I f**k it up cheers Leighton Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 6, 2013 Report Share Posted January 6, 2013 How did it get so dirty?As said,don't put any kind of cleaning stuff in there.Use ATE Superblue then you can't see the dirt! Quote Link to comment Share on other sites More sharing options...
