Scottscotland Posted December 8, 2012 Report Share Posted December 8, 2012 can someone please post a pic of a 1.0 mpi engine with the airbox off Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted December 9, 2012 Report Share Posted December 9, 2012 what do you need to know?ps theyre not the prettiest of engines lol Quote Link to comment Share on other sites More sharing options...
Scottscotland Posted December 9, 2012 Author Report Share Posted December 9, 2012 where the vacuume pipes gofrom the top of the rocker cover to the top or bottom of the inletand the same for the crank breatheralso is there a vacuume when the engine is warm when you remove the oil filler capheres a video Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted December 9, 2012 Report Share Posted December 9, 2012 Is this any help?http://forums.clublupo.co.uk/index.php?showtopic=24762theres 3 breather pipes one from the crank (the one you covered in the video) one from the erg valve and one from the top of the cam cover, the last two fit into the left side of the engine cover. Quote Link to comment Share on other sites More sharing options...
JoeA Posted December 10, 2012 Report Share Posted December 10, 2012 They go into either side of the air box. The one on the drivers side is thicker, thats the PCV breather. Then theres two on the passenger side, one (the thinner of the two) is the egr breather which, naturally, goes to the top of the egr valve. The other (on the passenger side) is the rocker cover breather, a single piece rubber pipe about 10" long. It goes to the hole on the right hand side on the top of the engine, the rocker cover. Quote Link to comment Share on other sites More sharing options...
Scottscotland Posted December 10, 2012 Author Report Share Posted December 10, 2012 ok im going to take a pic Quote Link to comment Share on other sites More sharing options...
Scottscotland Posted December 10, 2012 Author Report Share Posted December 10, 2012 ok here we go ,i know 5 goes to 11 (also i see there is a screw in 6?) Quote Link to comment Share on other sites More sharing options...
Chrisbee Posted December 10, 2012 Report Share Posted December 10, 2012 (edited) 6 is just a screw for the airbox don't worry about that.9 goes to 7. 8 is the egr valve breather but you don't seem to have the pipe in the pic which should be under 9 somewhere.As for 1 and 2 i can't say without checking minebut this thread has pictures of the engine in, which might helphttp://forums.clublu...showtopic=81377 Edited December 10, 2012 by Chrisbee Quote Link to comment Share on other sites More sharing options...
