Daryl Mechanic Posted September 7, 2012 Report Share Posted September 7, 2012 (edited) The ProblemMy brother in Law just got a Lupo 1.4 Sport 16v, AFH engine, Cable throttle.The revs keep dropping on it.Try and hold it at a constant RPM and it will be fine for 4 or 5 seconds then the revs will drop.Sometimes they drop lower than other times.Sometimes they come back up to where they were, sometimes they don't and it goes to idle level.Relavent HistoryAparently the guy who sold the car said it had had a new Throttle Body fitted at some point.What I have triedFirst AttemptStraight away I noticed quite a bit of oil in the air filter, coming in from the crank breather pipe. So I thought that might be the problem. Cleaned out the breather pipe as it was blocked with thick mayo, then cleaned out the crank breather filter/seperator box as that was blocked too.Then I noticed oil leaking from the underside of the intake manifold, so I opened that up and cleaned it all out and re-sealed with some high temp silicone gasket.While it was apart I noticed that the sensor on the left side of the Intake manifold (opposite side to the Throttle body) was covered in oil, so I sprayed a bit of electrical contact cleaner on it.I also cleaned out the inside of the Throttle body, just the butterfly area, I did not open up the black cover.So I put it back together and the problem was still there.Second AttemptI have mechanic friend who has just got an expensive new Snap-On fault scanner so I borrowed that and pulled the codes. But neither of us really know how to use it other than to pull engine codes and turn off engine/service lights.It came back with:00519 Intake Manifold Pressure Sensor (G71) Open Circuit / Short With Power Intermittant00518 Throttle Position Sensor (G69) Open Circuit / Short With Power Intermittant0530 Throttle Position Sensor (G88) Open Circuit / Short With Power Intermittant00523 Intake Air Temp Sensor (G42) Open Circuit / Short With Power Intermittant00282 Throttle Position Actuator (V60) Output Open IntermittantThere was no engine light on, so I thought that perhaps these were old codes from when the old throttle body failed.So I hoped that cleaning them might sort the problem and I could also see if any of the codes came back.So I cleared the codes and the problem was still there.I was testing it while parked on the drive for about 40 mins and none of the fault codes have come back.Third AttemptIt had a function on the scanner to 'Reset Throttle Body' so my mate tried it. Anyway it did its thing, we tried it and the problem was completely different and much worse!! It wouldn't hold stable revs at all.So we did a code scan and it came back with: 01087 Basic Setting Not PerformedSo I went and googled that while he kept trying the 'Reset Throttle Body' function and did all the actuator tests on the scan tool. When I came back out the code had gone and the problem was back to its original state. PhewwwWhat Can I Do Next?- Can I open up the black plastic part of the Throttle Body and clean out anything in there?Anything else? after that I'm stumped.......Please Help!! Edited September 7, 2012 by Daryl Mechanic Quote Link to comment Share on other sites More sharing options...
nellytheelephant Posted January 19, 2013 Report Share Posted January 19, 2013 (edited) take it to vw to diagnose Edited January 19, 2013 by nellytheelephant Quote Link to comment Share on other sites More sharing options...
marcyd Posted January 21, 2013 Report Share Posted January 21, 2013 I had the same problem with my sport ,try take off the throttle body and the black case and rotate the cogs a couple times clean the inside of the throttle body to makesure no black **** is inside the bore , put it back then check all your spark plugs and change if neccesary, I did that to mine and hey presto .....( Not gauranteed to fix it) but worked on mine Quote Link to comment Share on other sites More sharing options...
lindylou Posted January 28, 2013 Report Share Posted January 28, 2013 it might be potentionometer had this problem on my old golf. the thing was giving the ecu wrong info and so it kept trying to adjust the revs hence the irratic realy bad reving even when accelerator pedal not used .check if this was changed as it is part of the trottle body assembly hope this helps. Quote Link to comment Share on other sites More sharing options...
