Owen33 Posted September 7, 2012 Report Share Posted September 7, 2012 have no idea why but central locking started closing itself at random yesterday, unluckily the first time it done it was key was in the cubby hole but the passenger window was down a touch so just grabbed a long pole and finally pressed the button...it done it 3 or 4 times after while i was out and in the car. Its done this before but it was more opening itself, just after i locked it?? :S:SAny knowledge? Quote Link to comment Share on other sites More sharing options...
grazo22 Posted September 8, 2012 Report Share Posted September 8, 2012 disconnect the battery and then leave it 10 mins or so then re attach it. From memory I believe it resets the modules for the central locking and the electric windows. My passenger window wouldn't go down more than half way, did this and it was mended Worth a shot I suppose Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted September 8, 2012 Report Share Posted September 8, 2012 I don't know much about fixing cars but this wont cost you any money and you never know it might fix it. Try taking the central locking button on the drivers door apart and cleaning the terminals on it. maybe a bit of muck is shorting it out. Before taking it apart try disconnecting the switch for a day and see if that makes the problem go away, if so you know its the switch.I used to work for a coach company and the fitters were always moaning about drivers using silicone sprays to clean the dashboard as this would get into the switch's and break them. Quote Link to comment Share on other sites More sharing options...
Owen33 Posted September 10, 2012 Author Report Share Posted September 10, 2012 yeah i've had the switch out since i wrote this and it was really dirty/corroded, which is weird as only had the switch in a few month Quote Link to comment Share on other sites More sharing options...
electricracer Posted October 13, 2012 Report Share Posted October 13, 2012 did you fix this? Quote Link to comment Share on other sites More sharing options...
Owen33 Posted October 15, 2012 Author Report Share Posted October 15, 2012 yep, was just a corroded switch shorting out Quote Link to comment Share on other sites More sharing options...
