Trout13 Posted September 2, 2012 Report Share Posted September 2, 2012 Lupo 2001 1.4 16VI need to replace the sealing plug that the vacumn hose goes into but the problem is you can only get a new sealing plug by buying a new servo (I checked with lupoboy). Does anyone know what size of grommet/seal is required. It is important to get it exactly right as any leaks affect the brakes.When sourcing a replacement throttle body what numbers must match, there are 3 lines of numbers on it (see below)?408.238/321/003036 133 062B01.02.2 IIIAny help appreciated Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted September 2, 2012 Report Share Posted September 2, 2012 036 133 062B is the part number, match that and you should be fine Quote Link to comment Share on other sites More sharing options...
