alexander Posted August 28, 2012 Report Share Posted August 28, 2012 Hello,I wonder if anyone can help me. I am finding it difficult to change gears when the engine is warm. When the engine is cold, gear changing is nice, smooth and easy.. I this a problem with oil? Or i it more serious?Any help much appreciated. Cheers Quote Link to comment Share on other sites More sharing options...
Rich Posted August 28, 2012 Report Share Posted August 28, 2012 A. You've just joined up as you've got a problem with the car, that is bad craic, if I was feeling super sarcastic I would leave more sarcasm. I'm not so . . . B. Change the gearbox oil, it is a 17mm plug socket, your local VAG or TPS should be able to provide you with the right stuff/amount.C. If you used the forum more and integrated you could speak to LupoBoz and he will hook you up with what you need. Quote Link to comment Share on other sites More sharing options...
alexander Posted August 30, 2012 Author Report Share Posted August 30, 2012 Thanks Rich. Quote Link to comment Share on other sites More sharing options...
