mattbagshaw Posted August 15, 2012 Report Share Posted August 15, 2012 was just wondering if anyone would be able to post a step by step guide to changing the springs on my mk2 arosa ?newbie Quote Link to comment Share on other sites More sharing options...
craigg!! Posted August 16, 2012 Report Share Posted August 16, 2012 Are you just changing the springs or the shockers too? Quote Link to comment Share on other sites More sharing options...
Silver! Posted August 16, 2012 Report Share Posted August 16, 2012 There is a thread in the "Archive and How To" section, which detailed fitting coilovers.http://forums.clublupo.co.uk/index.php?showtopic=16199entry208787It is easy to follow, just concentrate on the spring part. No need to remove the rear shocks, just remove the bottom bolt and drop the rear beam and the spring will pop out.You will need a 7mm allen key and a 21mm\20mm deep reach ring spanner and a set of spring compressors for the front.If you don't have access to the correct tools it may be cheaper to get someone to fit them for you.Probably get a small garage to do it for less than £100. Quote Link to comment Share on other sites More sharing options...
