JGTTDI2 Posted July 23, 2012 Report Share Posted July 23, 2012 (edited) Please help, got a seat arosa 1.0 mpi with an engine misfire, I have changed the egr valve, spark plugs, ht leads, and cleaned the throttle body and fixed a slight split in the intake hose, I'm fresh out of ideas, the car idles fine but any throttle at all and It drops a cylinder or 2, it is unsafe to drive due to constant misfire under load, could it be a valve dropped?Please please help, thinking of setting it on fire! Edited July 28, 2012 by JGTTDI2 Quote Link to comment Share on other sites More sharing options...
Pete91 Posted July 23, 2012 Report Share Posted July 23, 2012 coil pack? Quote Link to comment Share on other sites More sharing options...
sonny.s Posted July 23, 2012 Report Share Posted July 23, 2012 Have you changed the rotor arm and dizzy cap only cost you £20 £30 for both. Worked wonders for my engine and misfiring Quote Link to comment Share on other sites More sharing options...
JGTTDI2 Posted July 23, 2012 Author Report Share Posted July 23, 2012 I will try the main coil, do you think that would cause it to misfire under load?Thanks Quote Link to comment Share on other sites More sharing options...
Pete91 Posted July 23, 2012 Report Share Posted July 23, 2012 Yeah the coil pack could cause a missfire Quote Link to comment Share on other sites More sharing options...
Miss Posted July 23, 2012 Report Share Posted July 23, 2012 I've just had that changed the coil pack was fine so do that it's my lamba causing it now DOH Quote Link to comment Share on other sites More sharing options...
JGTTDI2 Posted July 25, 2012 Author Report Share Posted July 25, 2012 I will try that, its so annoying!Thanks Again. Quote Link to comment Share on other sites More sharing options...
Miss Posted July 25, 2012 Report Share Posted July 25, 2012 I changed leads coil pack and sensor all sorted just dam temp gauge to sort now lol Quote Link to comment Share on other sites More sharing options...
JGTTDI2 Posted July 28, 2012 Author Report Share Posted July 28, 2012 Good news, went for bosch super plus plugs and fitted a set of new genuine leads and its running great for now Quote Link to comment Share on other sites More sharing options...
