RobbHancock Posted June 10, 2012 Report Share Posted June 10, 2012 My standard arosa speakers in the front door panels need replacing...badly! I've blown them to bits so they just crackle at any level of bass :/ sad times. Anyway...I took the door panel of to check the size and noticed they are riveted...? I've got some new speakers and the adapter ring thing on order but can someone explain how I'm supposed to get the old ones out?! I've seen people say drill it out but how? With a standard drill..? I'm new to all this stuff so any help will be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Alex-Bone94 Posted June 10, 2012 Report Share Posted June 10, 2012 Use a drill, Drill threw the middle of the rivets and that should make you able to pull the speakers out Quote Link to comment Share on other sites More sharing options...
RobbHancock Posted June 10, 2012 Author Report Share Posted June 10, 2012 Use a drill, Drill threw the middle of the rivets and that should make you able to pull the speakers out Oh is it that simple? Sound! Will give it a go when the weather gets a bit better then Quote Link to comment Share on other sites More sharing options...
Alex-Bone94 Posted June 10, 2012 Report Share Posted June 10, 2012 Yh I sorted my loop out with a sound system and there's 4 rivets in each speaker, drilled threw the middle of all 4 and speaker pulls out Quote Link to comment Share on other sites More sharing options...
RobbHancock Posted June 10, 2012 Author Report Share Posted June 10, 2012 Sweet! Will check it out and post some pics when it's done I'll contact you if I get stuck Quote Link to comment Share on other sites More sharing options...
Alex-Bone94 Posted June 10, 2012 Report Share Posted June 10, 2012 Its easy mate! Let us know how you get on Quote Link to comment Share on other sites More sharing options...
Silver! Posted June 10, 2012 Report Share Posted June 10, 2012 Drill only needs to be slightly bigger then the cantre hole of the rivet. Just drill 'til the outer "disc" comes away and then push the remains of the rivet through.You'll need some of these to remount unless you are ging to rivet them back in.http://www.amazon.co.uk/BargainBitz-Speedclips-Spire-Clips-Panel/dp/B007OUZ34W/ref=sr_1_1?ie=UTF8&qid=1339367525&sr=8-1 Quote Link to comment Share on other sites More sharing options...
RobbHancock Posted June 10, 2012 Author Report Share Posted June 10, 2012 i've ordered these...http://www.dynamicsounds.co.uk/autoleads-sak3106-seat-arosa-1997-165mm-front-doors-speaker-adaptor-p-3004.htmlwill that not be enough to mount it? Quote Link to comment Share on other sites More sharing options...
Silver! Posted June 11, 2012 Report Share Posted June 11, 2012 Yes, but you will have to fix them to your inner door, using either rivets or screws. If you choose screws you will require those little plates to slip over the mounting holes to provide something for the self tappers to screw into.You can get them from Halfords or any DIY store. Quote Link to comment Share on other sites More sharing options...
RobbHancock Posted June 11, 2012 Author Report Share Posted June 11, 2012 Got the speakers and mounts delivered this morning...they look great. They actually came with some of those dodgy metal things you linked me to so i should be in business as soon as the bloody rain stops Quote Link to comment Share on other sites More sharing options...
James827 Posted June 11, 2012 Report Share Posted June 11, 2012 Drill only needs to be slightly bigger then the cantre hole of the rivet. Just drill 'til the outer "disc" comes away and then push the remains of the rivet through.You'll need some of these to remount unless you are ging to rivet them back in.http://www.amazon.co...39367525&sr=8-1I used Raw Plugs. hahaits holding out well Quote Link to comment Share on other sites More sharing options...
RobbHancock Posted June 17, 2012 Author Report Share Posted June 17, 2012 Sooo...it's done!! put them in yesterday between the breaks in the rain Sounds superb! Quick question though...does anyone know how to take the grills out of the door panel? Wanna put the ones i got with the speakers in Quote Link to comment Share on other sites More sharing options...
