ChristopherReeve Posted June 7, 2012 Report Share Posted June 7, 2012 (edited) I've been looking and ive found thread polo gti conversions but non specific to my need so sorry if this is a repost I'm getting a lupo with engine failure and it needs a new engine, the engine code is AWHI can get a polo gti engine with;5 speed boxwiring loomecukeytranspondermanifoldwater pipesheader tankmountsgear selectorsstarter motorand all the sensors.All of these parts are OEM polo parts and it needs to be fitted into a lupo with the code awhMy questions are -Straight fit in?what mounts do i need?anymore info i should need?any before you ask i'm a honda specialist, not volkswagen The more info the better Edited June 7, 2012 by ChristopherReeve Quote Link to comment Share on other sites More sharing options...
georgen Posted June 9, 2012 Report Share Posted June 9, 2012 The mechanical is nothing, the electrical on the other hand is, easiest way is to strip interior out, strip dash out, take front off car, take engine and box out, take complete wireing harness out, now fit polo harness you will have to do some plug work and if you have central locking and electric windows it will be a pain, then put it all together again. ps No, ARC or AVY code engines will not run off AWH wiring and Ecuwould be easier if you got lupo gti harness Quote Link to comment Share on other sites More sharing options...
truCido Posted June 10, 2012 Report Share Posted June 10, 2012 I see you're from Somerset...I'm currently looking for engine bits Can I ask what failed on the engine? Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted June 10, 2012 Author Report Share Posted June 10, 2012 The mechanical is nothing, the electrical on the other hand is, easiest way is to strip interior out, strip dash out, take front off car, take engine and box out, take complete wireing harness out, now fit polo harness you will have to do some plug work and if you have central locking and electric windows it will be a pain, then put it all together again. ps No, ARC or AVY code engines will not run off AWH wiring and Ecuwould be easier if you got lupo gti harnessThat's exactly what u thought! Isnt polo gti engine fly by wire? And awh cable throttle? Quote Link to comment Share on other sites More sharing options...
ChristopherReeve Posted June 10, 2012 Author Report Share Posted June 10, 2012 I see you're from Somerset...I'm currently looking for engine bits Can I ask what failed on the engine?It was bore wear which led to oil burning in the cylinders fella :/ Quote Link to comment Share on other sites More sharing options...
georgen Posted June 10, 2012 Report Share Posted June 10, 2012 (edited) That's exactly what u thought! Isnt polo gti engine fly by wire? And awh cable throttle?depends on year but if your awh loop has a cable throttle, you will need fly by wire throttle then, not exactly a deal breaker tho. cos if you use harness it just plugs in Edited June 10, 2012 by georgen Quote Link to comment Share on other sites More sharing options...
