Brad1992 Posted May 23, 2012 Report Share Posted May 23, 2012 hey guys, probably quite a common fault and have had it vagcom'd, just wanna see what your idea of how to solve it is.the three codes i got yesterday when i had it vagcom'd by my friend lupopo were17953, 17963 +17912i had it vagcom'd as my car keep randomly cutting out and then being in like a limp mode state as the car will just feel real... limp - any idea what could this be?i believe its the throttle body fault, a manifold pressure signal or something + and air intake system bypass leak - any idea on what this means and how i can sort these?Gonna attempt to clean the throttle body tomorrow to see if its clogged up with crap!thanksbrad. Quote Link to comment Share on other sites More sharing options...
NOCK Posted May 23, 2012 Report Share Posted May 23, 2012 http://wiki.ross-tech.com/wiki/index.php/ Quote Link to comment Share on other sites More sharing options...
Brad1992 Posted May 23, 2012 Author Report Share Posted May 23, 2012 thanks, that website showed about the throttle body and checking that but not the others Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 29, 2012 Report Share Posted May 29, 2012 (edited) As you said, clean the TB, that should sort the first one.The second fault refers to boost pressure, are you sure you got the number right? Unless its referring to crankcase pressure/MAP sensor readings, not sure though.The third relates to an air leak in the intake manifold setup somewhere, this may cure itself once you have cleaned the TB. If not squirt carb cleaner at random places until you hear the engine not change - thats where your air leak is.Cleaning the EGR valve wouldnt hurt either! Edited May 29, 2012 by Defcon5 Quote Link to comment Share on other sites More sharing options...
Brad1992 Posted May 29, 2012 Author Report Share Posted May 29, 2012 ok, i'll give those a go tomorrow, so when i put them back on will i need to vagcom again or will it be alright? Quote Link to comment Share on other sites More sharing options...
