jamielupo Posted May 5, 2012 Report Share Posted May 5, 2012 Tryed fitting a set of fk corsa b rear struts to the lupo today today and found that the bottom bolt size is not the same the corsa run bigger bolts and also the strut its self is not as wide what moddifing needs to be done to the car/coilovers to make them fit thanks in advance for any help Quote Link to comment Share on other sites More sharing options...
bowers155 Posted May 5, 2012 Report Share Posted May 5, 2012 drill the rear strut to right size? Quote Link to comment Share on other sites More sharing options...
north wales loop Posted May 5, 2012 Report Share Posted May 5, 2012 drill the hole bigger and use washers either side Quote Link to comment Share on other sites More sharing options...
jamielupo Posted May 5, 2012 Author Report Share Posted May 5, 2012 Great thanks though that would be the case thanks for the reply ill have to dig some bolts out Quote Link to comment Share on other sites More sharing options...
