gavinhendy
swansea gearbox hell
something big went bang in my gearbox last night and i now need a new one, the car is a 1.4s , anybody have or now for a gearbox in the swansea area
cheers
gav
Thought about a rebuild instead? What actually happened?
hey defcon, turns out the gearbox is working as i had to start it in first then get the revs right to make changes to get the car home,
this is what happened - i went to pull off from a stand still and all i hear is a loud snapping noise from up front and my clutch is on the floor. Checked the cable and thats fine.
The release bearing has been noisy for a while and now where the cable meets the plunger that goes into the gearbox , that plunger has no stifness to it anymore, its loose , sorry if its hard to make out what im saying but thats all iu know for now untill it goes to the garage
Cheers
Gav
Edited by gavinhendy
Tbh mate its sounding like the clutch pressure plate has failed! Isn't a common fault as far as I'm aware! By plunger do you mean the arm the clutch cable connects to? If so its probably the pressure plate!
Hope this helps
J
New clutch kit and you will be all in working order then
£60 DIY jobby ;)
yes thats right lupopo that arm , im going to go about taking the gearbox off with a mechanic friend at some point soon,
cheers for the help
Gav
