gearbox leak
I smelt a horrible smeel whilst driving so i looked under the car when i pulled over and its leeking gearbox oil by where the drive shaft goes into the gearbox by the looks of it , it was falling on my exhaust and burning to cause a horrible smell , mt gears have also been a little stiff to engage , not a lot just a little ,
The leak is quite bad , a drop every 3 seconds!! will this be a seal that needs replacing ? or something worse , this is my first problem with the loop :(
Edited by gavinhendy
This is a leek...
What you have is a LEAK!
Joking aside, yeah sounds like a seal has gone mate. Best start of small first. No point buying a whole new CV when it might only be a seal. Best thing to do, wipe away the excess oil underneath, and make sure its coming from the driveshaft. If so then more than likely a seal.
cheers mate , leek is the national vegetable of wales lol ,
its coming from the drive shaft, i had the **** shields off today after work to top up the gearbox oil, it took about 200ml , just going to keep topping it up until i get some time and spare cash to book it into garage , thanks for your help
gav
  • 1 month later...
  • 4 weeks later...
ive got my gearbox out after an oil leak, they leak from either when they fail, badly a hole occurs inside the bell housing - new box
or gear selector shaft seal, 4 quid ebay can be done with gearbox in.
or input shaft seal box out there is a half moon cutout on the bottom of bellhousing oil leaks from there, box out.
