_joey_ Posted January 15, 2012 Report Share Posted January 15, 2012 as title says, yes i have searched the forum to no avail !basically the hazards work fine, but no indicators at all even the relay does not click. the parking light works ok tho ? Im lost as to what it could be as i assume the relay would either work for both or be broken for both. also i guess it cant be the stalk as the parking light works ?also has anyone had the issue of the clutch pedal moving the biting point? for instance the biting point was fine than all of a sudden it went really high, the clutch wasn't slipping at al then it went back to normal ? Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 If the clutch has corrected itself, wait till it happens again, if it ever does.Indicators. The hazard button is the relay. If they're not working then I'd say the first thing to do is remove the steering surround and check the wiring on the stalks. If nothing is amiss then I'd change them. Quote Link to comment Share on other sites More sharing options...
_joey_ Posted January 15, 2012 Author Report Share Posted January 15, 2012 so if the relay is working for the hazards then it is ok and the fault is elsewhere ?thanks Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 Stalks, check the wiring and possibly change them. Quote Link to comment Share on other sites More sharing options...
Lupoluke69 Posted January 15, 2012 Report Share Posted January 15, 2012 Neither my hazards or indicators are working! -.- my dads a merchanic so hes gonna have a look and ill let you know Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 Neither my hazards or indicators are working! -.- my dads a merchanic so hes gonna have a look and ill let you know You're likely to be the relay then. Quote Link to comment Share on other sites More sharing options...
Lupoluke69 Posted January 15, 2012 Report Share Posted January 15, 2012 Oh right how much is that do you recon then mate? Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 However much fatasss will charge you.(or do a scrappy run) Quote Link to comment Share on other sites More sharing options...
Lupoluke69 Posted January 15, 2012 Report Share Posted January 15, 2012 I went to the scrappy but that was before i realised :L I brought a new wing, hinges, speakers, pedal box for £40 Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 That's a pretty good haul.The relay/hazard switch is the same in the 6n2 Polos, the stalks are the same as well. Quote Link to comment Share on other sites More sharing options...
heartagram Posted January 15, 2012 Report Share Posted January 15, 2012 I have that relay/switch some where. I'm sure it is somewhere. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 You mean it's sitting in a cardboard box with the Polo GTI xenons ?I spotted it earlier. I've also got a few but for the effort of posting and amount they're worth, I'm just not bothering. Quote Link to comment Share on other sites More sharing options...
heartagram Posted January 15, 2012 Report Share Posted January 15, 2012 I could be tempted. Since I do have to go to the post office on a regular basis. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 15, 2012 Report Share Posted January 15, 2012 you should seize the opportunity before Paz does. Quote Link to comment Share on other sites More sharing options...
heartagram Posted January 15, 2012 Report Share Posted January 15, 2012 I'm sure _joey_ will seize the opportunity. All he needs to do is drop a PM.. Quote Link to comment Share on other sites More sharing options...
Rich Posted January 16, 2012 Report Share Posted January 16, 2012 Pm ftw. Quote Link to comment Share on other sites More sharing options...
lupolad Posted April 8, 2012 Report Share Posted April 8, 2012 JoeyDid you fix yours in the end - was it the relay as I have same problem as You. Hazard fine no indicators suddenly stopped. Parking light fine. Quote Link to comment Share on other sites More sharing options...
