Tomjw Posted January 9, 2012 Report Share Posted January 9, 2012 How do I remove the bolt that causes the CLANK CLANK CLANK noise when I open the door, I used a spanner but it kept turning... Am I doing something wrong? Thanks Tom Quote Link to comment Share on other sites More sharing options...
Ashh Posted January 9, 2012 Report Share Posted January 9, 2012 Which bolt? the one on the car or door? Quote Link to comment Share on other sites More sharing options...
Tomjw Posted January 9, 2012 Author Report Share Posted January 9, 2012 When you open the door and you see the strap its the bolt holding it onto the car Quote Link to comment Share on other sites More sharing options...
FunkyNutbar Posted February 1, 2012 Report Share Posted February 1, 2012 The door straps are my next job. Gonna do the trick here: http://forums.clublupo.co.uk/index.php?showtopic=78249 but need to know how to get in about it before I do too! Quote Link to comment Share on other sites More sharing options...
Liam-R Posted February 1, 2012 Report Share Posted February 1, 2012 Remove the lower door card (torx screws at bottom) then give it a good pull and it should pop off. You should now see the bolts that hold the strap to the door. Have fun! Quote Link to comment Share on other sites More sharing options...
