davidelliott294 Posted December 30, 2011 Report Share Posted December 30, 2011 Hi,Bought a new check strap from Lupoboz a while back and since i fitted it, the door has been making this terrible noise:http://tinypic.com/player.php?v=20zspvo&s=5Solution? I've read something in the how to section but not sure if it applies to this.. Quote Link to comment Share on other sites More sharing options...
puggled Posted December 30, 2011 Report Share Posted December 30, 2011 Have you got it on back to front? I can't see any sign of the notchy bits. Just looks like a smooth bar. Mine has the notches facing you.And slather it in lithium grease. Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted December 30, 2011 Author Report Share Posted December 30, 2011 Nope, It's the same as the other door. Creaking one: http://www.flickr.com/photos/69359558@N05/6601599317/in/photostream/The other door: http://www.flickr.com/photos/69359558@N05/6601601281/in/photostream/ Quote Link to comment Share on other sites More sharing options...
georgen Posted December 30, 2011 Report Share Posted December 30, 2011 The plastic bush aint in where the bolt goes through on car end, the noise is it springing against bolt. Quote Link to comment Share on other sites More sharing options...
georgen Posted December 30, 2011 Report Share Posted December 30, 2011 if thats ok as puggled says lash loads of grease in sliding part, and make sure all bolts are tight. Quote Link to comment Share on other sites More sharing options...
davidelliott294 Posted December 31, 2011 Author Report Share Posted December 31, 2011 The plastic bush aint in where the bolt goes through on car end, the noise is it springing against bolt.Not quite sure what you mean? Quote Link to comment Share on other sites More sharing options...
puggled Posted December 31, 2011 Report Share Posted December 31, 2011 The bolt at the pivot should have a sleeve over it. Quote Link to comment Share on other sites More sharing options...
bobbo Posted December 31, 2011 Report Share Posted December 31, 2011 You may have also overtightened the bolt where it bolts onto the actual body of the car Quote Link to comment Share on other sites More sharing options...
