MissBrown Posted May 20, 2012 Report Share Posted May 20, 2012 Rolling the lip and adding one washer this weekend... hopefully that should give me the clearance i need!!Did you manage to camber the rears using washers? as a friend of mine said it doesnt work on lupo's :s .... something to do with the stub axle??? Quote Link to comment Share on other sites More sharing options...
JordanVW Posted May 20, 2012 Author Report Share Posted May 20, 2012 Did you manage to camber the rears using washers? as a friend of mine said it doesnt work on lupo's :s .... something to do with the stub axle???Yeah i had a little problem with the brakepad carrier hitting the caliper!!.. im sure if i spent a day on it it could work! Quote Link to comment Share on other sites More sharing options...
MissBrown Posted May 20, 2012 Report Share Posted May 20, 2012 Did you end up using camber shims then?? i could just do with a slight bit of camber thats all .... Quote Link to comment Share on other sites More sharing options...
JordanVW Posted May 20, 2012 Author Report Share Posted May 20, 2012 Did you end up using camber shims then?? i could just do with a slight bit of camber thats all ....Nah i sold the car before i could be bothered to sort that side of things out.i reckon all you would need to do is space the sub axle then camber it?should be fine after that.. i was trying to run silly camber though!4washers on front bolt, 3 on the back! so thats probably why Quote Link to comment Share on other sites More sharing options...
shee Posted March 4, 2013 Report Share Posted March 4, 2013 15 or 16 inches wheels on this? Quote Link to comment Share on other sites More sharing options...
