loopy29 Posted October 6, 2011 Report Share Posted October 6, 2011 Hi iv ordered a set of wind deflectors and the fitting guide is a pile of pants I thort they slipped inside the window rubber but the guide says they stick in so any tips on fitting them stupid I no they look so easy to fit but knowing me il snap something ;-) Quote Link to comment Share on other sites More sharing options...
puggled Posted October 6, 2011 Report Share Posted October 6, 2011 What make are they? I had Club Hekos on my last few motors.They have a strip of double sided sticky tape, peel this, insert into channel, close window and leave for 15 mins.They also come with metal clips to put in but I didn't need them on the Corolla or Transit. They stayed in fine without.Lupo window is different shape so I don't know if you might need them? Quote Link to comment Share on other sites More sharing options...
parkin Posted October 6, 2011 Report Share Posted October 6, 2011 Were do get them from dude Quote Link to comment Share on other sites More sharing options...
loopy29 Posted October 6, 2011 Author Report Share Posted October 6, 2011 From eBay they have the sticky tape on them do I just pull the rubber down stick on put rubber back and wind window up ? Quote Link to comment Share on other sites More sharing options...
puggled Posted October 6, 2011 Report Share Posted October 6, 2011 Take the tape off and slide it up, sticky side pointing towards you, into the slot in the rubbers where the window goes then put the window up.Its really simple. I think you are over thinking it. Quote Link to comment Share on other sites More sharing options...
loopy29 Posted October 6, 2011 Author Report Share Posted October 6, 2011 I thort you hade to pull the rubber out the way then stick to metal window frame and replace rubber I wouldn't think it would stick to rubber plus in the instructions it's telling me to use panel wipe to clean the surface 1st Quote Link to comment Share on other sites More sharing options...
rapidebrothers Posted October 7, 2011 Report Share Posted October 7, 2011 There a two minute job to fit mate! Like the other guy said just lower down the windows, peel off the double sided tape & insert into the channel - making sure you press firmly into place, then raise back up the windows, then leave for a while!Mine are Team Heko ones & were new & only came with double sided tape, no clips but are still holding on! Ok mate Quote Link to comment Share on other sites More sharing options...
