Boot Handle
siobhan
Hi,
Thanks for the reply,
I called my nearest VW earlier,and was told £62.11 + VAT, then I'd need to get it painted too.
I told them I only needed the handle itself, not the whole lot so maybe I was quoted for everything? :confused:
How much did yours cost?
Thanks,
Siobhan
Sure I was quotes about £30, but as I said, it was on back order.
Is yours bubbling?
Try and get a used non silver one as apparently it's only the silver paint that reacts with the alloy. Not sure if I really get that though as they are all porous water baed primes.
I had a black one I picked up for a fiver and it's that one which is now on my car.
I will have a boot lock and key for sale Friday when I pick my car up from the bodyshop that's all you need not the full handle if that helps
hi i have one in flash red it has corroded above the handle so would need sanding back when you get it painted
