Red Lup Gti Posted February 7, 2005 Report Share Posted February 7, 2005 righto then people, this only really affects people that are out of warranty and are tight style="vertical-align:middle" emoid=":lol:" border="0" alt="laugh.gif" /> when i was traveling long distances i noticed that my clutch pedal was `non-existant`, but when i pumped it up it was mint! style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> so basically there was air in system! 1. unscrew `brake-clutch` resoirvoir and top up with dot 4 brake fluid.2. pump clutch pedal 5 times and hold pedal down using piece of wood wedged between seat and pedal.3. locate clutch slave cylinder (is on top of gearbox on gti) there is a 11mm bleed nipple ontop of cylinder, get a piece of pipe to go over the nipple and a old can or tray to place at the other end of pipe! 4. open nipple with your 11mm spanner until u see fluid (normally black style="vertical-align:middle" emoid=":(" border="0" alt="sad.gif" /> ) 5. tighten bleed nipple back up and pump cluth pedal 5 times and hold pedal down again with wood! 6. repeat process's `1-5` around 5 times and don't forget to tighten bleed nipple back up :roll: (refit rubber bung on nipple) take for a test drive to see if this has sorted the problem style="vertical-align:middle" emoid=":P" border="0" alt="tongue.gif" /> (normal disclamer applies) good luck! Quote Link to comment Share on other sites More sharing options...
one litre wonder ;) Posted February 7, 2005 Report Share Posted February 7, 2005 QUOTE(Red Lup Gti)(normal disclamer applies) is that the if u ****** it up u have only got urself to blame type of disclaimer ??? LOL! Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 7, 2005 Author Report Share Posted February 7, 2005 style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
paulbin Posted February 7, 2005 Report Share Posted February 7, 2005 would holding the bitting point on the clutch make the brake fluid hot and change the colour? Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 7, 2005 Author Report Share Posted February 7, 2005 nope, constant battering of the brakes would tho! clutch slave cylinder only moves a little rod with moves the clutch fork which inturn moves the thrust bearing style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" /> Quote Link to comment Share on other sites More sharing options...
paulbin Posted February 7, 2005 Report Share Posted February 7, 2005 ah similar setup to the mini style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted February 7, 2005 Report Share Posted February 7, 2005 Thanks for that Ross.My pedal is really bad, I didnt realise there was something I could get done. I'll book it in with them.Top bannana. Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 7, 2005 Author Report Share Posted February 7, 2005 andi, think the 1 litre is cable opperated clutch bud! Quote Link to comment Share on other sites More sharing options...
paulbin Posted February 7, 2005 Report Share Posted February 7, 2005 im not 100% but i think the sport MIGHT be cable aswell Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted February 7, 2005 Report Share Posted February 7, 2005 lmao thats what I thought before reading this Ross.Ive been thinking to myself that the clutch may be ready for changing.When I read this I thought Id gotten out of takeing the 'box out lol Quote Link to comment Share on other sites More sharing options...
tdwindustries Posted February 8, 2005 Report Share Posted February 8, 2005 This should be in the How To section, and good lad Ross - bring yer wood with you and you can do mine on Sunday. Quote Link to comment Share on other sites More sharing options...
Red Lup Gti Posted February 8, 2005 Author Report Share Posted February 8, 2005 no problem timbo, take us 5 mins max!! Quote Link to comment Share on other sites More sharing options...
