Reed Posted March 7, 2011 Report Share Posted March 7, 2011 Offering my camera up for sale as I need the cash I bought if off my Grandad a couple of years ago, he's fishing journalist and he had just updated to a 1D.It's by no means new, but it is mint and if you know about DSLR's then you know how good this camera is.Original box included, all manuals and disks. (Original <£1k receipt just for laughs )Will come with:- Polarising filter- 1GB Compact Flash (CF) card- Camera strap- Mains chargerAfter £300 ono, bargain if you ask meCollected from Kent (CT19 5QF) or Ultimate Dub'sWould rather not post to save sensors etcHere are the technical specs from Canon.co.uk:Features * 8.2 MP * 5 fps with up to 23 frame burst * 9-point AF * DIGIC II * E-TTL II distance-linked flash * USB 2.0 Hi-Speed/Video Out * Magnesium alloy body * Compatible with Canon EF/EF-S lenses and EX Speedlite flashes * DPP RAW processing software * PictBridge compatible Balance. Poise. Precision.QualityA rugged magnesium alloy body provides the first clue that the EOS 20D is no ordinary camera. Canon’s award-winning CMOS technology delivers outstanding image quality and 8.2 Megapixel resolution. The DIGIC II architecture drives blistering 5fps continuous shooting with a maximum burst of 23 frame JPEG images, class-leading colour rendition accuracy, quick start-up times and rapid display and zooming of images during in-camera review. JPEG and RAW files write simultaneously with no loss of performance.Focus9 auto focus points are carefully distributed across a wide area of the frame for fast, accurate focusing, even with off-centre subjects and particularly with ‘rule-of-thirds’ compositions.Distance-linked flashThe E-TTL distance-linked flash algorithm takes factors such as lens distance information and ambient light readings into account for accurate flash metering, even in circumstances such as recomposed shots, or where high or low reflective objects appear in the frame. The camera is compatible with the entire EX-series Speedlite flash range. This includes the 580EX, which transmits colour temperature information for improved colour stability and auto zooms to match the camera’s APS-C sensor size.Lens mountThe EOS 20D is compatible with more than 60 Canon EF lenses, including Canon’s EF-S lenses. Built with the EOS 20D photographer in mind, the EF-S 10-22mm f/3.5-4.5 USM and EF-S 17-85mm f/4-5.6 IS USM cover popular wide (approx. 16-35mm) and standard (approx. 27-136mm) ranges in the 35mm equivalent.Full controlAn extreme high (3200 ISO) setting extends the camera's wide 100-1600 ISO speed range. Both sRGB and Adobe RGB colour spaces are supported. Digital Photo Professional image processing software permits high-speed processing of lossless RAW files.ConnectivityThe EOS 20D’s USB 2.0 Hi-Speed connection enables fast download of images to the computer. PictBridge compliant, the camera supports direct printing to any compatible photo printer. It takes both CF and CF-II cards, including cards of over 2GB capacity. Quote Link to comment Share on other sites More sharing options...
Reed Posted March 11, 2011 Author Report Share Posted March 11, 2011 Bargain DSLR anyone, it's fully charged so I can bring it to UD's if you want to start using it straight away! Quote Link to comment Share on other sites More sharing options...
Rudaz Posted March 11, 2011 Report Share Posted March 11, 2011 Bump good luck with this!! I paid more for mine and it's not nearly as good!! Quote Link to comment Share on other sites More sharing options...
JamesU Posted March 11, 2011 Report Share Posted March 11, 2011 Great camera! Quote Link to comment Share on other sites More sharing options...
