pubblue Posted February 15, 2011 Report Share Posted February 15, 2011 Im Just wondering would these weller wheels fit my arosa 1.4 tdi, because i dont really know alot about it tbh lolThe wheel specs are:PCD: 4 x108mm Diameter: 14"Width: 6"Offset: ET -12Thanks. Quote Link to comment Share on other sites More sharing options...
j22drury Posted February 15, 2011 Report Share Posted February 15, 2011 theyll be poked but skinny Quote Link to comment Share on other sites More sharing options...
gordonbrown Posted February 15, 2011 Report Share Posted February 15, 2011 theyll be poked but skinny youll need wobble bolts too with them being 4x108 Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted February 15, 2011 Report Share Posted February 15, 2011 youll need wobble bolts too with them being 4x108You wont need wobble bolts , as the wheels are totally the wrong pcd and simply wouldnt fit with or without wobbles.Keep looking for some 4x98 or 4x101.6 that can be used with wobbles or plain old 4x100 will fit no problems ET and width dependant Quote Link to comment Share on other sites More sharing options...
gordonbrown Posted February 15, 2011 Report Share Posted February 15, 2011 my bad, thought you could get away with it (: Quote Link to comment Share on other sites More sharing options...
Adam R4 Posted February 15, 2011 Report Share Posted February 15, 2011 4x108 is a ford PCD isnt it?Coudnt he run PCD adapters? Quote Link to comment Share on other sites More sharing options...
Clarkie Posted February 16, 2011 Report Share Posted February 16, 2011 you could run adaptors 4x100-4x108, theyre not so common adaptors but there was a set on edition38 iirc last few days Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted February 16, 2011 Report Share Posted February 16, 2011 wellers are usually a low number offset anyway so often adaptors are a no go , plus they are usually expensive as they arent exactly an off the shelf item. Probably easier to weld and re-drill Quote Link to comment Share on other sites More sharing options...
