crist you would have thought they would have supplied the small cut out, to fill the gap in the bonnet. For that amount of £££££££££
Edited by FLO7LXJ
I am not sure I have seen MK6 Polo's with a color matched section, only problem is you could see it was just added in. If it was done right with welded sheet metal and blended it would look good. It would be very expensive.
Maybe talk to the other Lupo owners as the may have the same problems.
Good luck anyway.
