Pete Posted July 15, 2010 Report Share Posted July 15, 2010 Ok, I'm wanting to paint my original GTI alloys, going for either white or black, or both!! Now at the mo they're in their original silver with a few scuffs here and there. Am I right in thinking this is the best plan of attack?-Remove tyres from wheels-Strip old paint from wheels -Smooth off scuffs as best as possible to leave a decent finish-Give the wheels two or three coats of metal primer-Give the wheels two or three coats of selected colour-Give the wheels two or three coats of lacquer-Refit tyresAm I missing anything or got anything wrong??Fanx! Quote Link to comment Share on other sites More sharing options...
Silver! Posted July 15, 2010 Report Share Posted July 15, 2010 I'm not sure about the prep and spraying, but you did forget to remove the valves and balancing weights Quote Link to comment Share on other sites More sharing options...
Pete Posted July 15, 2010 Author Report Share Posted July 15, 2010 Heehee I knew someone would say that!! Silver..........have a lollipop and go to the top of the class! I'm not sure of coat quantity either but figured you cant go far wrong with three!! Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted July 15, 2010 Report Share Posted July 15, 2010 pretty much flat the colour back before you laquer ad flat the laquer back then polish to a high shine.. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 15, 2010 Author Report Share Posted July 15, 2010 pretty much flat the colour back before you laquer ad flat the laquer back then polish to a high shine..Thanks for the advice fella but I've got no clue what you just said!! How do I make sure the paint is flat? I'm not wanting to come across like a smart ass as I'm clearly not, and you obviously no what you're on about, but any chance of a laymans version to someone who's never attempted any paint/prep work before!! Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted July 15, 2010 Report Share Posted July 15, 2010 by flat back i mean hit it with with some very fine wet and dry paper( 1200-1500 grit or higher) to remove the "orange Peel Effect" Quote Link to comment Share on other sites More sharing options...
PaperWeight1 Posted July 15, 2010 Report Share Posted July 15, 2010 (edited) Colour shouldn't be flatted, clear should be sprayed onto a tacky colour.Clear is then flatted and polished.I wouldn't use 1200 to remove OP on aerosol paint, it's very soft.Wheel should be keyed/flatted with 800-1200 after primer to get a smooth base and a better key for colour. Edited July 15, 2010 by richie.guy Quote Link to comment Share on other sites More sharing options...
