Kuszpit Posted June 21, 2010 Report Share Posted June 21, 2010 Having a problem with the keyfobs on the Lupo GTI. We were parked at the supermarket and when I came up to the car the buttons on the key were not unlocking the car. I placed the key in the drivers door lock and turned it when I opened the door the alarm when off and kept on going for a good 5 minutes. I even tried turning the key in the ignition but the alarm kept going.I ran back into the shop and purchased two new batteries and placed them into the two keyfobs I have but both are not working. Eventually it stopped and I was able to drive the car without looking like I stole it. Does the keyfobs have to be coded again? Is there some process to go through on the keyfob to make them work the alarm again or do I need to purchase some new ones?Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 21, 2010 Report Share Posted June 21, 2010 Procedure1. Switch Ignition ON and leave the key in the ignition.2. Mechanically lock the vehicle using the Drivers door using a secondkey.3. Using the remote control press the Unlock button once, and the hornwill sound once.4. Wait 6 seconds and press the unlock button once to activate the codingprocedure. The remote control will now be programmed.NOTE : When performing programming on additional remotes the procedureis the same, except you press the unlock button 2, 3 or 4 times for thedifferent remote.For example : If programming 2 remotes press the unlock button twice witha 1 second interval between each press, repeat for 3 and 4 remotes.5. Switch Ignition OFF.6. Remove key from ignition and check for operation.7. The coding procedure can be repeated up to 4 times for additional remotes.8. The ignition must be switched OFF between programming each remotecontrol.Try this. Quote Link to comment Share on other sites More sharing options...
hunid-brake Posted June 21, 2010 Report Share Posted June 21, 2010 i had an issue with this when replacing batteries in one of my fobs. I asked for help and got about 5 different procedures each one slightly different to the next and none of them worked, this one is new to me so will have to try this one as well now lol. one day my tidy fob will work again Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 21, 2010 Report Share Posted June 21, 2010 i had an issue with this when replacing batteries in one of my fobs. I asked for help and got about 5 different procedures each one slightly different to the next and none of them worked, this one is new to me so will have to try this one as well now lol. one day my tidy fob will work again That deffo works, coded a new fob to my mums car tonight. Also worked with your existing keys fine. Quote Link to comment Share on other sites More sharing options...
hunid-brake Posted June 21, 2010 Report Share Posted June 21, 2010 ideal, well its gone back to the body shop for them to fix the shoddy work they did (VW approved repairers-lol) so will give it a bash when i get it back. At the moment they gave me a citreon c2 vtr, its so slow its painful so am guessing its the 1.1i or the 1.4. Either way i am not impressed at all Quote Link to comment Share on other sites More sharing options...
jon_273 Posted June 22, 2010 Report Share Posted June 22, 2010 Try this.So the key you are trying to code goes in the ignition? Or in the door?Do you have to have a remote key in the ignition? Reason I ask is I have tried procedure before with no success. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 22, 2010 Report Share Posted June 22, 2010 So the key you are trying to code goes in the ignition? Or in the door?Do you have to have a remote key in the ignition? Reason I ask is I have tried procedure before with no success.Key to be coded in door, and a key in the ignition.There is a video on youtube, but I can't find it. Quote Link to comment Share on other sites More sharing options...
Kuszpit Posted June 23, 2010 Author Report Share Posted June 23, 2010 Gave it a shot but it is not having it. Both keyfobs have brand new batteries but when you press them none of them have the red light coming on. When you put the key in the ignition and then one in the door the horn isn't sounding.Would it be worth getting two new keys which are the newer three button type and get them coded by VW. My brother works for Audi so has contacts at VW.Thanks Quote Link to comment Share on other sites More sharing options...
gucciwah Posted July 17, 2010 Report Share Posted July 17, 2010 what if you only have one key? how can you program that as mine doesnt work. i changed the battery and the light comes on but nothing happens. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted July 17, 2010 Report Share Posted July 17, 2010 what if you only have one key? how can you program that as mine doesnt work. i changed the battery and the light comes on but nothing happens.Should be able to follow the instructions in the hand book. Quote Link to comment Share on other sites More sharing options...
gucciwah Posted July 17, 2010 Report Share Posted July 17, 2010 this is gonna sound stupid and im abit annoyed with myself aswell... but when i bought the car i forgot to ask for the hand book ...i dont even think he had one. anyway... if its in the hand book i'l try and source one out and check it out. cheers Quote Link to comment Share on other sites More sharing options...
