Golf+sezza Posted June 19, 2010 Report Share Posted June 19, 2010 Hi there,I've now lowered my Lupo GTI and need to get it 4-wheel aligned to sort out tracking and camber settings properly.Can't afford VW main dealer prices - from £150!!!!Can anyone recommend an independent specialist or tyre place in Kent that they've used?Thanks Sezza Quote Link to comment Share on other sites More sharing options...
jamiea7x Posted June 19, 2010 Report Share Posted June 19, 2010 the rear isnt adjustable, so you dont need 4 wheel alignment Quote Link to comment Share on other sites More sharing options...
Golf+sezza Posted June 20, 2010 Author Report Share Posted June 20, 2010 In that case then, it just needs the front steering geometry to be aligned, e.g tracking and camber... have a feeling laser alignment would be better... Quote Link to comment Share on other sites More sharing options...
nfbr Posted June 20, 2010 Report Share Posted June 20, 2010 4-Wheel Laser Alignment doesn't necessarily mean adjusting all four wheels. On a 2WD Car with Fixed Rear axle, it means Matching the Front wheels alignment to that of the rear. You still have to set up the gear onto the rear wheels before you can begin setting up the front Toe/Camber/Caster angles. Quote Link to comment Share on other sites More sharing options...
northwick Posted June 20, 2010 Report Share Posted June 20, 2010 ^correct. Quote Link to comment Share on other sites More sharing options...
