Jag Posted January 8, 2010 Report Share Posted January 8, 2010 HelloLupo Gti51 plateI went to top up my oil today and when I took the cap off I saw this yellow cream like substance on the bottom of the cap. I know to look out for white mayonnaise like substance but this stuff is yellow. Is it the same thing, and what could it mean?Thanks Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted January 8, 2010 Report Share Posted January 8, 2010 Its just because its cold, dont worry about it - If you thunder down the m-way for an hour it will go away but it isnt doing any harm Quote Link to comment Share on other sites More sharing options...
jon_273 Posted January 8, 2010 Report Share Posted January 8, 2010 Probably the same thing as the usual white mayonnaise stuff. It is caused by frequent short journeys. Follow Defcon5's advice Quote Link to comment Share on other sites More sharing options...
Jag Posted January 9, 2010 Author Report Share Posted January 9, 2010 Cheers Quote Link to comment Share on other sites More sharing options...
nfbr Posted January 10, 2010 Report Share Posted January 10, 2010 (edited) If you get Fully Synthetic oil next time you service the car, this can sometimes cure the yellow gunky stuff! Edited January 10, 2010 by nfbr Quote Link to comment Share on other sites More sharing options...
Bigfoot Posted January 12, 2010 Report Share Posted January 12, 2010 Its emulsified oil (water mixing with oil).If your car has a slight oil leak around the head/ rocker cover it could be letting moisture in and causing it.Aslong as the cars going fine, don't worry about it. Quote Link to comment Share on other sites More sharing options...
