northwick Posted June 16, 2009 Report Share Posted June 16, 2009 Had ABS light come on and sometimes I can feel the ABS pump applying the brake onto the front left at slow speeds (when I'm not even pressing the brake pedal!)Plugged in VAG-com. Says intermittent fault of front right abs sensor. Given its braking the front left and it says right sensor, from what point of view does it mean 'right'? Drivers? Or looking at the car face on?Could see how front right sensor (from drivers view) would confuse system and make it brake front left wheel (from drivers view), but it could also be on the same side if its viewing from the front and I need to know which part to order. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted June 16, 2009 Report Share Posted June 16, 2009 Had ABS light come on and sometimes I can feel the ABS pump applying the brake onto the front left at slow speeds (when I'm not even pressing the brake pedal!)Plugged in VAG-com. Says intermittent fault of front right abs sensor. Given its braking the front left and it says right sensor, from what point of view does it mean 'right'? Drivers? Or looking at the car face on?Could see how front right sensor (from drivers view) would confuse system and make it brake front left wheel (from drivers view), but it could also be on the same side if its viewing from the front and I need to know which part to order.Drivers side on a UK car. Quote Link to comment Share on other sites More sharing options...
