henlupo Posted May 14, 2009 Report Share Posted May 14, 2009 HI THERE LOOKING TO CONVERT MY GTI FRONT BRAKES FROM 256 TO 280MM G60 AS I CAN TELL FROM THIS GROUP THIS COULD BE THE NEXT MOD FOR ME. BUT THERS A LOTS OF TALK..... BUT NO PART NUMBERS FOR CARRIERS,DISK,PADS, OEM PART NUMBERS PLEASE, WHO'S THE DADDY ON THIS MATTER. Quote Link to comment Share on other sites More sharing options...
matt~black Posted May 14, 2009 Report Share Posted May 14, 2009 ebay vr6/mk3 gti carriers Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted May 14, 2009 Report Share Posted May 14, 2009 G60 carriers - 357 615 125 cG60 front discs - 535 615 301 Quote Link to comment Share on other sites More sharing options...
henlupo Posted May 15, 2009 Author Report Share Posted May 15, 2009 will standard gti pads work or will i need g60 pads"as one is thicker than the other" cheers Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted May 15, 2009 Report Share Posted May 15, 2009 i'm using oe gti pads 6n0 698 151 b no problems as its only 2-3mm difference! Quote Link to comment Share on other sites More sharing options...
henlupo Posted May 16, 2009 Author Report Share Posted May 16, 2009 many thanks mod on it's way Quote Link to comment Share on other sites More sharing options...
gilybob Posted May 16, 2009 Report Share Posted May 16, 2009 (edited) got a quote for the carriers today from vw £82.64 ... that about right ?? think i may go second hand ... Edited May 16, 2009 by gilybob Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted May 16, 2009 Report Share Posted May 16, 2009 yep, sounds about right to me!trade for the pair works out around £165ish Quote Link to comment Share on other sites More sharing options...
gilybob Posted June 25, 2009 Report Share Posted June 25, 2009 (edited) ok so im having an argument on ebay with sum dude .. vw breakers .. hes saying that you cant get g60 carriers from vw any more ?? and the part number ive quated the part number above and he says thats the wrong thats 288 summit or rather from a golf so i dont know who or what to believe ...this is what the guy said !!nope 357 615 125c is not the part number for 280mm g60 carriers at all... that is the part number for mk3 288mm carriers.. and yes etka is showing up with 100's of them in the country at various maindealers.. but there not GENUINE G60 carriersany ideas ??? Edited June 25, 2009 by gilybob Quote Link to comment Share on other sites More sharing options...
gilybob Posted June 25, 2009 Report Share Posted June 25, 2009 any one ?? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted June 25, 2009 Report Share Posted June 25, 2009 (edited) erm..... the guy is a knob! The 288mm carriers as found on VR6 mk3 golfs is 4a0 615 125 athere are 2 parts numbers for g60 carriers, the earlier part number is857 615 125 (280mm)which is upto 1991, then they are 357 615 125 c (280mm)which can be found on corrado 1989 - 1995golf 1990 - 1996golf synchro 1986 - 1991golf estate 1994 - 1996jetta 1988 - 1992passat 1988 - 2000vento 1992 - 1996the 357 carriers are fine with Lupo's as I'm on my 3rd set of pads and second set of discs, and I've had NO problems whatsoever! My carriers came off a mk3 8v golf GTI with an ADY engine code (same as 2e and AGG) and I painted them red, as they don't come in red at all from VW. Edited June 25, 2009 by lupogtiboy Quote Link to comment Share on other sites More sharing options...
gilybob Posted June 25, 2009 Report Share Posted June 25, 2009 thank you dude ill copy and paste to him .. apart from the knob bit..i can get the 357 615 125 c (280mm for 47 pounds each from vw (mates rates) so ill order them nxt month thanks for the reply dude .. Quote Link to comment Share on other sites More sharing options...
henlupo Posted July 8, 2009 Author Report Share Posted July 8, 2009 MANY THANKS MOD COMPLETED AND PART NUMBERS ARE CORRECT G60 carriers - 357 615 125 cG60 front discs - 535 615 301 .WAS VERY LUCKY WITH THE VW CARRIERS FROM THE SCRAP YARD, DISC G60 STANDARD VW VENTED TYPE USED OLD PADS FROM THE VW GTI AS TO SAVE MONEY BUT WORK FINE.ALL STANDARD VW PARTS Quote Link to comment Share on other sites More sharing options...
sheps Posted July 8, 2009 Report Share Posted July 8, 2009 would i need any additional parts to do this conversion to a sport or is it literally just carriers and disks, then use standard calipers? Cheers Sam Quote Link to comment Share on other sites More sharing options...
henlupo Posted July 9, 2009 Author Report Share Posted July 9, 2009 hi sam, not sure mate look through the topics or go down the scrap yard and buy the calipers/carriers.... Quote Link to comment Share on other sites More sharing options...
