lupo pete Posted May 6, 2009 Report Share Posted May 6, 2009 i need to know whats behind the wing mirror is it just some black foam that sits in the plastic outeris that it ?or should there be a rubber seal to keep the water out the reason why i ask is my speakers cry when it rains and the water sit on the door sealsi have replaced the window seals so i know its not them..i have looked in the search engine whats best thing to ? Quote Link to comment Share on other sites More sharing options...
missy Posted July 12, 2012 Report Share Posted July 12, 2012 i need to knowwhats behind the wing mirror is it just some black foam that sits in the plastic outeris that it ?or should there bea rubber seal to keep the water outthe reason why i ask is my speakers cry when it rains and the water sit on the door sealsi have replaced the window seals so i know its not them..i have looked in the search enginewhats best thing to ?Hi lupo petedid you ever get an answer to your question? I have exactly the same problem! Quote Link to comment Share on other sites More sharing options...
Tomjw Posted July 12, 2012 Report Share Posted July 12, 2012 Hi mate Remove your lower door card where the speaker sits behind and you'll notice a grey foam cover? Thats what stops the water from leaking in. If its torn then the water will leak through, I have the exact same problem but because I removed mine to fix my speaker wiring. You can order new ones from a member on here called Lupoboz, look in the traders section then VW parts and send him a PM, he will get back to you fast with discounted genuine parts Hope this has helped Quote Link to comment Share on other sites More sharing options...
missy Posted July 13, 2012 Report Share Posted July 13, 2012 Hi mate Remove your lower door card where the speaker sits behind and you'll notice a grey foam cover? Thats what stops the water from leaking in. If its torn then the water will leak through, I have the exact same problem but because I removed mine to fix my speaker wiring. You can order new ones from a member on here called Lupoboz, look in the traders section then VW parts and send him a PM, he will get back to you fast with discounted genuine parts Hope this has helpedHey thaks for reply, i have the upper door card foam which i brought from vw but no lower? The water is hitting the speaker baffle n running over the speaker and into the footwell. Did yours do this too? I don't want ruined speakers again n theres an awful lot of water raining in the door is that normal? Quote Link to comment Share on other sites More sharing options...
Tomjw Posted July 14, 2012 Report Share Posted July 14, 2012 Hey thaks for reply, i have the upper door card foam which i brought from vw but no lower? The water is hitting the speaker baffle n running over the speaker and into the footwell. Did yours do this too? I don't want ruined speakers again n theres an awful lot of water raining in the door is that normal?You need the lower part which is called a water shedder. Contact Lupoboz and he will sort you out with the right part Im 100% sure thats the reason why, remove your lower doorcard and you'll see its either missing is damaged Quote Link to comment Share on other sites More sharing options...
missy Posted July 16, 2012 Report Share Posted July 16, 2012 You need the lower part which is called a water shedder. Contact Lupoboz and he will sort you out with the right part Im 100% sure thats the reason why, remove your lower doorcard and you'll see its either missing is damagedOk if your 100% sure then i believe you thanx Quote Link to comment Share on other sites More sharing options...
