TDI Help please!
hey, I have a vw bora 1.9 tdi pd 115 bhp, sometimes when i start it, it revs its balls off for afew seconds,this is problem 1, problem 2 i could be driving along and the turbo will just cut out, if i turn off the engine and restart it the turbo works again, but the turbo will still sometimes cut out again, it is doing my head in, i dont want to take it to vw as they will charge my an arm and a leg, any ideas anyone???? cheers gary
Problem 1. A faulty coolant or fuel temp sensor can cause a pd to rev up when started ( normally a check light on dash )
Problem 2. If you do get the fault memory checked there will be a fault regarding boost pressure regulation, the ecu knows the boost pressure is not within the range that it should be at that given rpm/load.
It could be a number of things from a split vac pipe,boost pressure control valve or it could even be a faulty turbo (sticky vnt)
