richardn Posted June 30, 2008 Report Share Posted June 30, 2008 hi,ive bought an amp wiring kit its mostly wired up just cant see anywhere for the wires to go from the engine bay into the car itself,if anyone has a pic of where they can go through it would be much appreciatedrichard Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted June 30, 2008 Report Share Posted June 30, 2008 when u lift the bonnet behind the engine on the right is a heat shield. behind this is a hole that leads into the car behind behind the dash. it can be reached through the passenger footwell to pull it through. Quote Link to comment Share on other sites More sharing options...
richardn Posted June 30, 2008 Author Report Share Posted June 30, 2008 when u lift the bonnet behind the engine on the right is a heat shield. behind this is a hole that leads into the car behind behind the dash. it can be reached through the passenger footwell to pull it through.is that the same on all luposmine is a 2002 tdi Quote Link to comment Share on other sites More sharing options...
